w124 Lighting ECU Fault
EasyManHugo
Telford
W124 coupe 320 coupe, XLWB Vito V6, C220 diesel estate
W124 300d (1994)
Indicators not working. Can hear a buzzing noise from the indicator relay in the fuse box when the stalk is operated. Changed the relay still the same. Changed the ECU with a salvaged ECU and worked properly for two weeks. All other lights and hazard warning light are working fine.
Would be grateful for any help as I've run out of ideas
Many Thanks
EMH
