WDB124066
- Apr 17, 2009
- 1996 E320 Sportline Cabriolet x 2
There is an "it" missing from that sentance. Changed the whole meaning, Grrrrr.
I have not studied the kit BUT a question that springs to mind is:
Presently the car has 2 suspension loading points, the spring perch, and separately the damper strut top mount.
This kit puts all (both) the spring and the damper force onto the top mount.
AS the car was never designed to cope with this loading, I would want some answers re the calculations.
A possible solution may be a helper spring remaining in the place of the original spring.
So, what should I do guys? Buy the kit or not?
HD's should be the same as the B6.
B4 are what we call in the US: "Comfort", not really that compatible performance wise with lowering springs.
In the USA there are both HD's and Sports in the B6 range.
HD's have identical valving with the Sport, but Sport uses an internal stop to limit the travel by 1".
I run HD's with H&R Sports lowering springs ( about 1.3" drop) and front and rear Sportline swaybars and front and rear strut/sgocktower upper bracing.
Ed A.
Reading your posts i understood, you have some great experience.
Could you tell me please what size rubber pads you used with H&R Sports lowering springs ( about 1.3" drop). Your w124 300ce looked just perfect. I am planing to use the same combination of springs & shocks in my 1995 W124 E320 coupe.
Have you ever had any rubbing? What size of wheels & tires you used?
I have AMG monoblocks R18 width:7.0 ET 31. Do you know if they fit?
