Dave Lewis
Hi chaps, help needed for '96 S124 E280 Estate. Symptoms: misfire on acceleration, (engine spits back then picks up), idle stumbles momentarily then recovers.
Car has new loom, new coils, new coil extenders/connectors, new water temp sensor, new air temp sensor, new Bosch Maf. I have read the codes, and on pin 8, the only stored code is 11. I cleared the code, restarted car, got code 11 again. From a PDF I have, code 11 is: "O2S 1 heater (before TWC) - Current too high/low or short circuit".
Anyone know what this refers to? Is this the O2 sensor? if so, where do I find it? It's about the only thing I haven't replaced.
Thanks!
Thanks!
