W124 sunroof - there is a god!
acm718
Stockport
1994 E320 estate
Had my car about ten days so far, one of the electrical faults was the sunroof wouldn't move apart from tilting up - no tilting down, and no sliding either way.
I've been fiddling over the past two evenings, fitted a new switch as the old one was sticky, even tried adjusting the clutch slightly to see if it made a difference - no joy.
I was expecting headliner removal and other fun to get a sunburnt forehead.
Just unclipped the relay pack, and it rattled - taken the relay to bits, and found one of the two solenoid return springs has rusted through and snapped - longnosed pliers formed a new eye from the end coil of the spring, hooked it on, and voila...
:bannana::bannana::bannana::bannana::bannana:
Anyone do the lottery? Try my numbers this week - you might win the jackpot!
Nice one!
That should read
There's probably no Webasto God. Now stop worrying and enjoy your sunroof
isn't it a GREAT feeling when you manage to fix something without spending a penny ?
Enjoy the sunshine !
I have all this fun yet to do. My sunroof on the estate is knackered and 99% closed. I just know I will have to strip out the lining. Will do a how to on it. Not that anyone would be interested ;)
99% of the sunroof mechanism is easily got at by sliding back the inner cover, unless the tray's rotten there's no need to go any further.
To clean out and re-grease the runners ( build up of dirt is usually the cause of slow operation on older cars ) the above is all you need to do - I usually pop it down at the front edge , slide the roof part way back , then withdraw the trim up and out through the aperture .
The other common problem is rotting of the drain channels at the corners of the tray . Of course , the 'proper' way to do this would be to remove the full cassette , but I once did a 'quick fix' on one of my 190E's by simply dropping the headlining at the top edge of a rear door , inserting a piece of plastic tube inside the rubber drain tube and into the tray where it was rotten then sealing all around with a hot-melt glue gun . I know it will eventually rot again but two years on still OK (fingers crossed) .
Just got to replace the hinge retainers and springs for the pop up wind deflector on the 126 now ( they were broken when I got the car and the deflector just lying loose ! ) .
YES! :D
All greased and lubed up now, (No, no, NO :doh: the sunroof, the sunroof...)
Smooth as silk. I'd been told it hadn't moved for three years :)
Oh, and what is this mythical creature 'the sunshine' of which you speak?
