Feb 7, 2011 #1 Sp!ke Administrator Joined Jun 2, 2002 Messages 11,968 Location West London Car SL500 & The Fart Car Anyone know how to get at it in a W201? I've done similar on a W124 but am unsure how to get at it on this car.
Feb 7, 2011 #2 stwat MB Enthusiast Joined Jun 20, 2004 Messages 3,176 Location Sheffield Car 1989 W126 300 SE If I recall correctly, lift out the wood surround and the bulb holder should pull out from the top right of the selector housing.
Feb 7, 2011 #3 OP OP Sp!ke Administrator Joined Jun 2, 2002 Messages 11,968 Location West London Car SL500 & The Fart Car There's no screw holding the wood surround then?
Feb 7, 2011 #4 stwat MB Enthusiast Joined Jun 20, 2004 Messages 3,176 Location Sheffield Car 1989 W126 300 SE Nope no screws, just clips. The best way is to remove a window switch and pull it up from there.
Feb 7, 2011 #5 W Will Hardcore MB Enthusiast SUPPORTER Joined Jan 21, 2003 Messages 14,149 Location Surrey Car GL63 AMG / SL500 / Porsche 911 As said, no screws on the wood surround. Just remove the plastic rectangular trim around the gearshifter and the whole panel will lift up. Be careful not to flex the wood or you'll crack the (fragile) lacquer. Bulb pulls out on the holder with wiring attached - push in the side near the top.
