Hi all
After a bit of advice regarding the ABS system, so thought I'd ask the collective knowledge to see if anyone else has had a similar problem.
On start up the BAS/ASR light comes on along with the ABS light and the brake wear indicator. Engine won't rev above 1,000 rpm which I presume is a safety feature. This happens while the car is in neutral and has not moved.
I've had a look around the forum and it appears that they are several issues which might be the source of the problem, however as this is happening before the car has been put into drive I'm wondering if this is suggesting the issue is more ABS speed sensor related and the system is showing the fault straight away as there possibly no signal from one or more ABS sensors.
As the car won't rev its gonna be difficult to drive it to my local MB indie to get the codes read
Has anyone else had similar issues and a fix?
Given the age of the car this could be its final hurrah, I was hoping to get it to 200k miles but might be short by 10k
thanks in advance, all comments welcome
cheers
GMC
cheers
GMC
