andy, there are a few variations of them, usually there is a paper label stuck to them, with a part number on it, or if not, ring your local dealer and give them your chassis number, and ask them for the part number.
Its item 83 in the link below, bout £20-25 IIRC, this number was gained by using my C43 AMG chassis no. if your car is a pre face lift they maybe slightly different in appearance. Êàòàëîã
Are you installing a new MB loom? or are you making one up? You can get all the connectors and crimps from MB as well. The complete loom is,nt very expensive i believe (if its still available).
I had an additional hole cut in my centre console very difficult to do properly you can see it has been cut after the fact and not done at the factory, I used a router to do it which is what WIS say to use.
You are aware that you may require additional looms for each door, as the MB loom only goes as far as the door separation point
