W202 Avantgarde Grille With Mercedes Logo
matrixcar / powerstyling stuff is normally Ok. Not perfect but good.
Make sure he packs it well as the grille slats can break in transit.
Thanks guys :) also, hows fitting, pretty straighty forward? im guessing the old one just clips out without having to remove the chrome frame that it's in?
You need to unscrew the frame and then unscrew the insert from it.
KillerHERTZ did a superb HOWTO but unfortunately the pictures are not showing anymore. Should be able to get the general idea though.
HOWTO
Used the same instructions when I fitted mine :)
I bought the same from the same seller when I had my 202. Quality is fine :)
Ditto, The company is called MatrixCar - on eBay its down as powerstyling though.
I bought the Avantgarde version about 2 months ago, It was about £45 all in, excellent quality :bannana:
As for the HOWTO: I still have the pictures on my PC, I will have to re-upload them
Here is a picture of the grille for those interested.
And before those who will slate it, the grille like all modifications is a personal choice ;)
I'll have to say that looks OK. I've seen a few versions that look poo. Still prefer the Avantgarde though if I had the choice :)
Your picture is a bit too "actual size"...I thought I was being run over.
Can you post a picture from further away to give an overall effect as opposed to close detail?
Also, is the star not straight?
Reduced sized pic :)
