Alex Argent
Anyone know if there are Brake Pad Sensors fitted to the rear pads on a facelift C240?
The reason I ask is that having quickly removed the rear wheels last night in order to spray a bit of WD40 onto the area where the discs meet the hubs (I'm changing the discs as well as the pads later today or maybe tomorrow, and the fronts were really difficult to release at this point due to being a very tight fit over the hub), I couldn't for love nor money see any pad wear sensors fitted nor indeed find any wiring to them.
This seems peculiar, as the stealership said I needed 4 (?) and there is half a reference to rear pad sensors in the Haynes bible (although the latter does not specifically cover the C240/C280 V6 models, it refers to pad wear sensors "where fitted"). Certainly there is no facility in the pads themselves to push in a sensor, as there is on each of the inner front pads.
I'm
Look forward to any replies.
Regards,
Alex
I'm
Regards,
Alex
