W202 brake pipes
samthesidecar
Kidderminster
'96 C250 - died when tubo went bang. '96 C200. Replaced by '99 CLK200 & missus' C180 Estate..
Hi folks, does anyone know what size the nut on the rear rigid pipe should be, where it connects to the flexi?
Mine seems to be somewhere between 10mm & 11mm - odd.
Cheers, Sam.
It's 10mm... a bit of a tight fit though.
Halfords sells brake hose spanners, which wrap all the way around (5 sided) which work a treat ;)
M.
Thanks for the reply, my 10mm flare nut spanner wouldn't look at it, I think I should get the files out!
