Amazing!! Not one punctuation mark of any kind!!![]()
OK so run with it disconnected for a while to see if the problem goes away - the ECU will assume a default air-intake temp which should be OK (probably more-so at this time of year).thanks for the help stevesey no there is no mas on the other side of the engine,thats the only thing that goes in to the air intake, and i just disconnected it, i didnt take it out as in photo
Hi.....it only seems to happen when just over 80 running temperature
I have the same problem aswell,
I was told the earlier 202 runs off manifold pressure,Not M.A.F?
I am in the same boat mate and i have got to the point of wanting to get shot of the 202 now.
I have changed PLUGS,COIL,LEADS,AIR TEMP SENSOR(that thing in the pic)
I also cleaned out the throttle valve flap. (not sure of the real name)
Someone i work with said you have to reset the throttle valve after you have cleaned it. somehow? could this be true?
