philhoward
- Dec 28, 2014
- W202 C250TD
Why is it a simple job turns into a nightmare?
Yesterday replaced the glow plugs - bit of a pig of a job but I've known worse. This morning was fitting a set of replacement injectors I'd rebuilt with new nozzles and it was going pretty well. Took a while to start (as I expected) but as I left it sat on the drive warming up (and defrosting!) saw a constant drip of diesel on the floor which looks to be coming from the lift pump/shut off valve? I've done a Google and it looks like a prime suspect is the o rings to the shut off valve - is this always the case or could it be leaking from one of the clear pipes which don't all seem that solidly in place? It apparently had "all" the o rings replaced about a year ago before I bought it (have an MB receipt somewhere) but the same searching shows that MB don't sell the ones for the shut off valve, just the whole valve so is it safe to assume these won't have been touched?
Now have a car that drips diesel about one drip every 5-10 seconds when it was running - turned it off to investigate further and now it won't start. Battery now on charge
Any help and/or advice would be most welcome! It started off a really good week of fiddling after I replaced the heater motor brushes yesterday
