Really that does surprise me, what car did you source the selector from? CLK? E class?
How does it compare to the original size wise? does the original trim surround still fit around the shifter?
If it does,nt fit as its to low it would seem to imply that the 202 tip shifter is different, i have seen tip versions of the 202 there does,nt appear to be any difference hieght, size wise, or the console.
I,ll have a look on the EPC after work for you see if i can see anything that might explain it.
