spock500
Hi all,
I wanted to check the vacuum lines before bolting the manifold back on as a quick test run revealed a very hard shift.
Problem is that I cant see any of the pipes or indeed the vacuum switch which looks to be attached to the IP?
Also I only have one white nylon pipe going to the box, none on the otherside of the box and the white pipe disappears into the wing amongst a wiring loom.
Any ideas whats, what
