I've been emailing www.hids4u.co.uk regarding their recommended kit for my W202. They recommend their Ultimate H7 kit, as this will not cause the bulb failure light to be on.
http://www.hids4u.co.uk/store/product.php?productid=64&cat=16&page=1
Has anyone used and can recommend this kit ?
Below is also their reply to my question, regarding road use and the Daniel Stern articule....
Hi William,
Thank you for your e-mail. Aftermarket HID kits are not technically road legal as you are replacing a halogen bulb with a gas discharge bulb. This means the gas discharge bulb cannot be E marked and is therefore not road legal. Do not be fooled by sellers claiming their kits are road legal, they aren't.
However our kits produce the correct beam pattern and colour so will pass an MOT.
That article to be honest is way over the top, it is true that if you don't have the light source in the same place as on a halogen bulb you will not get a correct beam pattern, however if the kit is good quality the it will produce the correct beam pattern.
His last statement is actually quite a funny one "Therefore, they cannot be overcome by additional research and development, any more than someone could develop a way for you to put on somebody else's eyeglasses and see correctly." If you picked someone who had the same prescription glasses as you then of course you would be able to see correctly! in the same way if the light source is in the right place then it will give the correct beam pattern.
What he says about projector headlights is just incorrect. We have a car here with projector lights and an HID kit fitted and the beam pattern is perfect, there is a much brighter and evenly spread light emitted and it has already gone through the MOT twice! He sounds like someone who had a cheap kit that didn't work properly and has decided to post an article damming them through spite. BUT at the end of the day, aftermarket HID kits are not and probably will never be road legal despite the claims of other sellers.
Kind Regards
Pete
HIDS4U Ltd
www.hids4u.co.uk
0844 8842600
Hi William,
Kind Regards
Pete
HIDS4U Ltd
www.hids4u.co.uk
0844 8842600
