salesac1
Newbie seeking help! I am doing a few straightforward mods to my C200 Classic Selection (W 2000) and bought a pair of these crystal clear indicators (the cheapest ones of course):
http://cgi.ebay.co.uk/Mercedes-C-Cl...ryZ14763QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Simple replacement I thought, but I am struggling to fit them. For fitting purposes they look virtually identical to the Bosch originals but somehow the front inner edge with its rubber seal seems to push up closer against the side of the headlamp surround and therefore will not allow the whole unit to slide into place. I can get the two plastic lugs on that side to locate at the entrances to where they should go, it is just that the unit itself doesn't want to push into place. I am holding open the internal securing clip from inside the bonnet whilst pushing the unit from the front, but no success. The originals however just slot back in perfectly.
What should be a quick job now seems like it may require adjustment of the headlamp surround to try to give a little more room to fit these indicators. I guess that what cheap gets you .
If anyone has fitted these, had similar problems or can give me any tips on fitting them, I'd be v. grateful.
Cheers..
Cheers..
