W202 Kompressor Bolt-On?
rizal2510
KL
Saw this on ebay.de and was wondering whether the conversion from normal to supercharged could be done by simply bolting on the kompressor? (by someone competent of course ) Any other issues that needs to be addressed before contemplating the job?
Mercedes Kompressor für W202,W208,W210 TOP !!!
Translated :
Translation
At that price it could be a worthwhile mod..for when the speed devil in you awakens :devil:
Translated :
Translation
Anythings possible if your determined enough(and have the ££££££££££££££),however the blower is just one part of the system;you would also need all the trunking/hoses,intercooler,MAS`s,ECU,airbox,inlet manifold,different pistons/head?(comp-ratio?)plus a whole box full of other gubbins.
Not really realistic is it?
Its interesting seeing that picture though because ive been wondering for a while if MB changed the drive to the blower-that one looks like it has a electromagnetic clutch on the pulley-mine does not.TOP!!!
I dont claim to be an expert in this area but I am also curious. So far the parts list comes down to this.
- new head gasket. Must be thicker to drop the idle compression
- new inlet manifold (plenum). About $200 Euro
- various air intake parts.
- some pressure hose for the intercooler
- intercooler (you can use AMG one here)
- reprogramme the ECU at MB dealer - download the K profile
- new V belt
- possibly some other new pulleys.
- air vent bypass (part of the air intake system).
Probably looking at about $1000 pounds worth including labour. Its a reasonably huge undertaking without the best advice. Maybe you can pick the brains of someone from Brabus or Kleeman before you go further.
I know Mercedes Performance do a K conversion but it runs out at £5500 so that should give you an idea of the task at had.
All we need now is someone to fax over the fitting list.
I looked in EPC and to my surprise I found that it looks somewhat different to the M271 setup.
Hmm...such a mammoth task to undertake for a K conversion..maybe easier to plumb in a Kompressor engine or change to a new car... :p
Oh dont be like that ..... what would be the joy of doing it if one could simply pay someone else to do it.
Well Toady B liar work like that all the time!!!
Not putting off the idea completely but would gather more info on it before deciding ...
If a low payed worker on the Dark Continent can bolt it on then what precisely would the reason why someone else cant do the same.
I think its time to find that retrofit OEM list.
