perdikoyla888
- Jun 24, 2006
Hi guys, i have a few faults with my air con. I started having ticking noises after upgrading the standard air con control fascia to the AAC digital air con control fascia. Here is the fault list that DAS STAR diagnosis gave me:
1) B1390 COMMUNICATION ERROR OF AC BUS WITH COMPONENT A32M2 (ACTIVATED CHARCOAL FILTER FLAP ADJUSTMENT MOTOR)
2) B1598 COMPONENT M2/8 (LEFT DEFROSTER ACTUATOR) IS STIFF OR BLOCKED
3) B13A0 COMMUNICATION ERROR OF AC BUS WITH COMPONENT M2/9 (RIGHT DEFROSTER FLAP ACTUATOR)
4) B15A8 COMPONENT M2/10 (LEFT FOOTWELL FLAP ACTUATOR) IS STIFF OR BLOCKED
5) B13B0 COMMUNICATION ERROR OF AC BUS WITH COMPONENT M2/11 (RIGHT FOOTWELL FLAP ACTUATOR)
6) B13C0 COMMUNICATION ERROR OF AC BUS WITH COMPONENT M2/20 (RIGHT FRESH AIR FLAP ACTUATOR)
7) B15C8 COMPONENT M2/6 (LEFT BLENDING AIR FLAP ACTUATOR) IS STIFF OR BLOCKED
8) B15D0 COMPONENT M2/7 (RIGHT BLENDING AIR FLAP ACTUATOR) IS STIFF OR BLOCKED
9) B1100 NORMALISING OF THE POSITIONING MOTORS IS NOT OK. ONE OR SEVERAL POSITIONING MOTORS ARE FAULTY, OR NORMALIZING HAS NOT BEEN CARRIED OUT
10) B1340 COMMUNICATION ERROR OF AC BUS WITH COMPONENT B32/2 (AAC SUN SENSOR (4 IN TOTAL))
11) B1350 COMMUNICATION ERROR OF AC BUS WITH COMPONENT B31 (C-AAC MULTIFUNCTION SENSOR)
12) B1021 COMPONENT N22/4 (REAR BLOWER ELECTRONIC SELECTOR WHEEL) HAS SHORT CIRCUIT OR IDLE SPEED. IMPORTANT NOTE: THIS FAULT CAN BE IGNORED IF NO BOOSTER BLOWER IS INSTALLED
RESULT OF ACTUATOR MOTOR MEASUREMENT:
ACTUATOR MOTORS THAT ARE NOT DISPLAYED ARE OK AND MAY NOT BE DISPLAYED.
13) A32M2 (ACTIVATED CHARCOAL FILTER FLAP ADJUSTMENT MOTOR [0..3616] 0 (0%)
14) M2 (LEFT DEFROSTER FLAP ACTUATOR) [0..2298] 1998 (87%)
15) M2/9 (RIGHT DEFROSTER FLAP ACTUATOR [0..2403] 0 (0%)
16) M2/11 (RIGHT FOOTWELL FLAP ACTUATOR) [0..1131] 0 (0%)
17) M2/19 (LEFT FRESH AIR FLAP ACTUATOR) [0..2555] 65535 (2565%)
18) M2/20 (RIGHT FRESH AIR FLAP ACTUATOR) [0..2520] 0 (0%)
I THINK FAULTS 1,10,11,12,13 ARE NOT APPLICABLE TO MY CAR SINCE I DOT HAVE THIS HARDWARE, I CHANGED THE AIR CONTROL PANEL TO THE LUXURY AAC BUT STILL THE REST OF THE HARDWARE IS THE STANDARD AIR CON.
For the guys that upgraded to the AAC digital control fascia: DID YOU CHANGE IN YOU CAR THE ENTIRE AIRCON HARDWARE WHEN YOU UPGRADED YOUR AIRCON? DID YOU FIT CHARCOAL FILTER, EXTRA 4 MOTORS, SUN SENSOR, AND MULTIFUNCTION SENSOR, HUMIDITY SENSOR, AND REAR BOOSTER BLOWER?
INFORMATION FOR WARRANTY CLAIMS DEPARTMENT:
KLA_UMLUFT: 1021
KLA_AKF: 0
KLA_ED_L: 1998
KLA_ED_R: 0
KLA_FR_L: 970
KLA_FR_R: 0
KLA_MD_L: 65535
KLA_MD_R: 0
KLA_TMK_L: 2658
KLA_TMK_R: 2625
WHAT PARTS DO I NEED? HOW MANY WORN PLASTIC COGS/GEARS/LINKAGES AND WHICH ONES IN SPECIFIC? ALSO HOW MANY STEPPER MOTORS YOU THINK MIGHT BE FAULTY? CAN YOU PROVIDE PART NUMBERS PLEASE? I HAVE ALREADY ORDERED THE FOLLOWING:
A 203 830 00 32
A 203 830 00 33
A 203 830 01 40
A 203 830 02 40
I DID NOT ORDER ANY STEPPER MOTORS A2038201642 YET AS THEY ARE MORE EXPENSIVE AND NEED TO KNOW HOW MANY FAULTY I MIGHT NEED TO REPLACE (IF ANY)
Thank you in advance for your attention into this matter.
KLA_UMLUFT: 1021
KLA_AKF: 0
KLA_ED_L: 1998
KLA_ED_R: 0
KLA_FR_L: 970
KLA_FR_R: 0
KLA_MD_L: 65535
KLA_MD_R: 0
KLA_TMK_L: 2658
KLA_TMK_R: 2625
A 203 830 00 32
A 203 830 00 33
A 203 830 01 40
A 203 830 02 40
