Jun 3, 2008 #1 I Imr4n Active Member Joined Jun 8, 2007 Messages 80 Where is the fuel filter located on a 2001 w203 C180? And is it a big job to chnage? thanks
Jun 3, 2008 #2 D Deleted member 2227 Guest Under the car, half way back. I didn't do mine and I wouldn't unless you know exactly what you are doing. Petrol isn't a great thing to play with or have spraying everywhere.
Jun 3, 2008 #3 OP OP I Imr4n Active Member Joined Jun 8, 2007 Messages 80 Thanks for the quick reply, is it under any covers or can it be seen clearly?
Jun 3, 2008 #4 grober MB Master Joined Jun 22, 2003 Messages 31,756 Location Perth, Scotland Car W204 ESTATE greyed out item here. http://www.detali.ru/cat/oem_mb2.as...624716.633&CT=F&cat=69J&SID=47&SGR=035&SGN=02 and item 130 here http://www.detali.ru/cat/oem_mb2.as...624716.633&CT=F&cat=69J&SID=47&SGR=015&SGN=01 you will need several hose clamps on the flexible pipes to isolate the filter before changing it.
Jun 3, 2008 #5 BlackC55 Authorised Forum Sponsor SUPPORTER Joined Feb 8, 2007 Messages 20,782 Location Portsmouth, Hampshire. Car E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up It is under a cover but can still be seenfrom the rear on the left.
