latinofever
- Jul 25, 2011
- Mercedes C Class - C270 CDI
Driving home in the fast lane I experienced a bang followed by a cloud of white smoke out the back. I then lost power although the car could be driven. I believe it went into LIMP MODE. Could only get up to 80mph max....
Anyway looking under the bonnet when I got home I notice that a large black pipe appears to have popped out. Not sure if its split. I believe this is the Turbo inlet pipe ( Can anyone confirm the name of this pipe so I can order a replacement if required?) I also noticed under the pipe there appears to be a lot of oil. Not sure if this is a different issue.
My question is. Do you think this pipe could be swapped by an amateur or does it need to go into a garage. Does the car need to be dismantled to swap it or can it be swapped by leaning over the car? Not sure if anyone has any instructions on how do do this.
