W203 External boot handle failed.
DSM10000
Hardcore MB Enthusiast
Near Salisbury
MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
The external boot release handle on my 2003 W203 saloon has stopped working.
The handle no longer opens the boot when operated and also has no sprung return so I assume it has failed internally, the boot still opens from the remote and from the internal button so I assume that the wiring is still OK, lights etc are all functioning.
Looking at the handle it seems simple to remove via a couple of screws so I am assuming remove, unplug, replace?
If anyone had a part number it would be helpful, I am going to find it difficult to get to my local dealer for some time but with the part number I can hopefully order and pay for it over the 'phone and have it delivered.
Of course if anyone has a working spare kindly let me know!
Thank you.
David
Thank you.
David
Might be worth oiling with WD40 or similar? Our W203 had the handle stuck in the open position occasionally which would prevent it from opening - not quite sure how it stayed closed though.
It has no sprung return which suggests it has failed in some way. I will take it out to look at the mechanism.
Solved
Thanks to all that replied and to Nick for the link.
I decided to take the mechanism out and have a look to see if anything obvious was amiss, the whole unit was caked in fine dirt and mud.
A few minutes cleaning and use of compressed air and spray lubricant and it is, for now, operating normally!
At least I know how to remove it and also where to find the part if needed.:thumb:
