Wully
Miro that maybe one for you as i using a quote from yourself on one of my other posts:
I believe the replacement of the rear lights from pre-facelift to facelift is not just a straight swap.
From searching through this forum and others i believe that the connectors require to be changed. Then there's the matter of the twin lamps on each of the clusters, as the pre-facelift only has one lamp how can this be changed? Is it only star systems with factory / developers mode that can do this? Do you know the part numbers of the connectors?
If i can't get this coding carried out will only one lamp work on each of the clusters and will this cause any errors?
miro said:If you know someone with Developer mode then you can also code the rear running lamps to be a complete horizontal bar instead of that lamp in the middle of the rear lights cluster.
