w204 c-class original mercedes tv tuner retrofit full parts list
perdikoyla888
Regarding the saloon/sedan tv tuner retrofit of c-class (in my case for a w204 lhd c250cgi car that already has keyless go and DAB tuner)
TV TUNER
most w204/w207/w212/w221 should work fine
TV WIRING HARNESS
a2044406006/a2045406513 for cars without KG or a2044403332 for cars with KG
TV MOST + WAKE UP
A2044404408 for cars without UCI or A2044405108/A2044409010 FOR CARS WITH uci
ANTENNA AMPS
front antenna amp TV
a2048204589 antenna amp + a2045405134 front windscreen contact cable
(There is also a chance that the front factory peinstalled windscreen glass a2046704001/a2046706701 might need to be removed and replaced with a2046703301/a2046706801 if it does not have the extra contact for the front TV antenna amp)
rear right c pillar antenna amp TV
a2048204089 superceded by 2048704794 antenna amp
(If the car has DAB we have to take out the already factory preinstalled rear right c pillar a2048205189 DAB antenna amp to install a2048204589 or 2048704794. This means we are left without DAB antenna amp. For this reason we have to replace as well the rear left c pillar basic main radio unit antenna amp a2048200089 with a combined main radio and DAB antenna amp a2048204989)
rear left top roof antenna amp TV
a2078203789 for only cars without KG or a2078200789 for all cars with or without KG
(If the car has KeylessGo we have to take out the already factory preinstalled rear left top roof a2048705390 KG antenna amp to install the combined a2048204589 KG+TV antenna amp.)
I hope this helps! :bannana:
