Hi ,
My car is a w204 , c200 2013 model - WDD2040486L047268. Car has done around 85000kms.
1st problem - Today i was speeding above 160kmph and as i increased my pressure on the accelerator pedal ,there was a kickdown in the gear box with a jerk , while it happened there was a drop in the rpm to below 1000 , the temp gauge dropped below 40 & the temp gauge symbol lighted up. All this happened for a fraction of second & once i eased on the accelerator pedal ,everything was normal. i was able to simulate it again at that speeds. so after i just drove at below 140kmph. I dint notice any issues with the ride after that. My mechanic did scan & said there was a code for auxillary gear box pump malfunction.
2nd problem - Btw yesterday i washed my car with a pressure washer & all of a sudden the parking lamps lighted up , dont know why it happened then ,
3rd problem - sometime back when the car was running idle and left with ac on during the summer , the car central locks activated automatically without anyone inside, then had to use additional key to open .
Kindly advise on how i should proceed with this issue ? can anyone help me with the part number of the gearbox auxillary pump ?
Brief history of the car - Car was sitting idle for almost 2 years at home , the ECU was changed , petrol pump was changed , all fluids & filters , all tyres, rubber mounts , front shocks .
