W204 C250 Coupe Rear Seat Removal
BryanLock
W204 C250 CDI Coupe
Anyone know how to remove the rear bench from a C Class Coupe?
I found a video for the saloon but seems the fittings may be different.
I've popped the front corners off their fitting but that's as far as I've managed to get so far.
Cheers
Bryan
Hi Bryan
You will have to pop both corners!! Then in one of the centre cup holders remove the rubber lining at the bottom of the cup holder
I believe it's the cup holder that is slightly larger!! Under the rubber you will find a screw with needs to be removed!!
Then pull the front of the seat up and push back to un-latch the back of the seat!! Once it un-latchs you can just pull the seat out
