W204 Turbo oil return line
Aded
Manchester
W204 C180 2012
Hi all, my car was repaired with timing chain done, but was leaking oil,I noticed oil from turbo oil line, but banjo bolt dried and I replaced banjo bolt washer all good.I changed the o ring that joint the block, that was ok and no oil leak from there since, but small leak also notice and I could see oil on the turbo return line at the engine block areas,I have bought the same o ring, but if I remove it from the block, turbo side got 2 pipes together, but the one that I need to remove is at the bottom, do I need to remove the bolt and pull out both and put o ring on both and fix it back ,advise pls. Thanks I will send the similar picture.
You won't be able to remove just one end of that pipe, you'll need to undo both ends to pull the pipe off and replace the o-rings.
Ok. Thanks I bought extra o ring anyway that we sort both and one at the block side.
