W205 2016 C250D - Electronic service sheet
Muna34
Mercedes C250D W205
Hi, is there away to check what is required on the next service. There was a website that you could go and check what was required. I can't seem to find it. Some links are now dead.
Looking at taking car to local garage and want to ensure I replace everything that is required.
2017 - Service A
2018 - Service B, brake fluid
2019 - Service A, pano roof lubrication (if fitted)
2020 - Service B, brake fluid, air filter, fuel filter
2021 - Service A, ATF & Filter (if automatic)
2022 - Service B, brake fluid, pano roof lubrication (if fitted)
2023 - Service A
2024 - Service B, brake fluid, air filter, fuel filter
2025 - Service A, pano roof lubrication (if fitted)
2026 - Service B, brake fluid, ATF & Filter (if automatic)
Note that cabin filter (aka pollen/dust filter) replacement is included with Service B and not considered an 'additional item'.
Also, check the Service Assist on your instrument cluster menu, it will show a code, e.g. A0 .
Thank you, that is really helpful. I will check Instrument Cluster Menu.
What does Service A include?
Service A comprises of engine oil and filter change, and a few checks.
Service B comprises of engine oil and filter change with a more comprehensive set of checks, plus cabin filter change.
Thank you Jay. This is very helpful.
