Play can't be checked. It's a visual check.
Just pull the lead off the plug and coil to check it. They are plug and play. No coding required.
Ok, I will tell the mechanic to visually check them... I don't know why I said play tbh
I have learnt that to pull the plugs off, there is a special tool called a 'boot removal tool' or something along those lines. Is this really needed or can all 12 leads be pulled off by hand?
