stereophoney
- Dec 10, 2012
- SLK32, Clio Diesel
Had my 55 for a couple of months now and still loving it, really quick and I got 24.3mpg on a 225 mile run!
One thing that is bothering me is the oil check warning. After 15mins of driving the 'check oil level' message comes up. If I pull over and switch off the display shows 1 malfunction, but won't show what it is. Turning the key to position 2 results in this message disappearing. If I do the oil measurement check it almost always says 'OK'. Sometimes it state 'Perf Serv ontime' and once it told me to 'add 2 litres'. Checking manually on the dipstick it has never been low. On a cold engine the level is a touch below max. It was changed by Mercedes about 600 miles ago. Once the oil is up to temperature it never comes on.
Does this sound like a sensor issue? If it is I understand the sump needs to be dropped, if that's the case I plan to leave it until Feb when it's due to be changed and sort it out then. I assume there's nothing wrong with that!
