cbmsys
- Dec 8, 2016
- W211 2004 E270 AMG; W215 2001 CL55 AMG (For sale); W209 CLK 320Cdi (breaking)
Hope somebody can help me with this, or point me at a thread.. I've read plenty so far but no help.
W209 CLK320Cdi V6 OM642 Engine, 130k miles. Been faultless since I bought it 5 months ago, at 125k. Has a Brabus D6 fitted, which has been removed since the troubles started, in order to eliminate this.
Troubles started a month ago with Turbo Actuator failure. Engine codes read, confirmed actuator fault and Lambda Sensor high voltage.
Recon actuator fitted, New Bosch Lambda sensor fitted, and oil/air filter service.
Still in limp mode, fault now sowing with Inlet port Motor, still also showing fault on turbo actuator and lambda.
New (MB Genuine) Port motor fitted. Still showing all 3 fault codes, and still dropping into Limp mode randomly.
I'm now at the end of my patience with this, and having cost me £500 in parts so far, I'm not prepared to spend any more money on replacing parts without actually finding out what the problem is. All the faulty components from the Star Diags have been changed, and all codes have come back. Any pointers gratefully recieved.
