So i've had the first major fault with my CLK after 60k of ownership - and was with the gearbox last weekend. I@m leaning towards this being conductor plate / ECU issues, but would appreciate help. In any respect, it sounds expensive
2006 CLK 320cdi / 130,000miles / two gearbox fluid services due to high mileage.
Problem:
Driving along the motorway, I went to accelerate out of an average speed zone and noticed that the car wasn't responding to throttle inputs.
* the "D" and "S" indicators either side of the odometer had disappeared.
* The converter didnt appear to tbe locked up in the gearbox - I could maintain speed, however.
* Pulled over, switched the car off, let it shut down (until cluster went blank)
* Started the car, - it could go into "D" but engaged violently.
* I could drive off, but couldn't get out of first gear.
Got the car recovered home, and connected it to my STAR.
Codes from STAR were as follows:
C1026 Fault in CAN communication with control unit N15/3 (ETC [EGS] control unit).
C1701 CAN communication with transmission control unit is faulty.
C1027 Fault in CAN communication with control unit N15/3 (ETC [EGS] control unit).
C2211 No CAN message was received from control unit N15/3 (ETC (EGS) control unit).
After disconnecting the STAR (I didn't clear the codes) the "D" and "S" reappeared in the dash cluster and I was able to drive the car about perfectly.
I haven't been able to get under the car to check this week as I had to fly out on a business trip. No fluid leaks that I can see.
I can see that there are plenty of issues with the conductor plate / ECU on these cars, but I don't seem to have (or have had) any of the specific trouble codes on these.
What should I be budgeting for in terms of getting this repaired? Any help on diagnosing this would be appreciated, thanks!
Problem:
