Hi all,
Gear box problem with my W209 CLK 2005 model
changed transmission oil Wednesday 02/08
same transmission problem a week ago any help or suggestion /repair cost will be appreciated.
Location BB7
RAC DIAGNOSTIC SYSTEM
System Type: ENGINE SYSTEM TEST/VALUES
Name: 272.940 - ME 9.7 - 3.0L - 170 (231)
DTC: 0983,cylinder 1
DTC: 1003,cylinder 5
DTC: 0521,Inlet flap control circuit; Short circuit to earth
DTC: 1781,Fault is stored in component Transmission control
DTC: 1805,Fault is stored in component Transmission control
System Type: GEARBOX
Name: GEARBOX - GEARBOX
DTC: 2767,Rpm sensor 3
DTC: 2768,unknown
System Type: CENTRAL ELECTRONIC UNIT
Name: SIGNAL ACQUISITION AND CONTROL MODULE - FRONT - SAMV203
DTC: B1044,Coolant level indicator switch and Windshield washer fluid level switch; open circuit
DTC: B1003,Heating water circulation pump; open circuit or Short circuit to ground
Location BB7
DTC: 2768,unknown
