W210 comand in W202 phone help needed
amg3.6
UK
C55 Amg White W202
I have w210 comand in my C43 but i want install the complete phone system so i can add bluetooth i already have viseoo 2 and i all ready purchased the complete phone system from w210.
The problem is the connector which is needed to connect the viseoo to isnt there its just the cradle and i have been told the w210 didnt have the pre wire connecter. The w203 has this connector but the wiring is different will it work with comand 2 from w210 or is there anything else i can do any help is appreciated.
You need the Viseeo MBU1000 or MBU3000 for the older phone system you have.
Could i do antything to get viseoo 2 working as I've already got it?
Hi Richard is the UHI system available for W210 e class?
So i have the fixed system isn't this good at all? And whats the difference between fixed and UHI system?
Yes, the UHI system is available for D2B cars (i.e Comand 2.0) and MOST cars (newer!)
UHI has a cradle you can change for various others, including bluetooth ones (although most mercedes Bluetooth cradles are not compatible with the D2B UHI system)
The fixed system takes a Nokia 6x10 (or 3110 before that)
Richard
Will UHI system work from W203 on w210 comand 2?
Ok thanks for info Richard. So the wiring i have cant i use that on UHI? And can the UHI be used for any phone controller i think the one i have seen on the w203 6150?
But the guy said the fibre optic is different on the w203 is this correct?
The only part that is the same between UHI and not-UHI is the microphone. Nothing else is useful.
W203 pre 2005 facelift, and W210 with COMAND are both D2B fibre optic.
R
Hi, has anyone got a layout for a 2001 w210 phone connection, i want to try something crazy, wiring-up a utp connector to a microusb connector, but i need to know the exact wiring module for it, in parallel to the microusb(charging only) i want to fit a jack to the rest of the wires
Thank you.
