Jan 6, 2012 #1 J jon_viola Active Member Joined Apr 3, 2007 Messages 305 Location Sussex Car S212 E350 CDI Aantgarde Sport Estate Just been reading the hand book and it says refer to dealer regarding transmission fluid. Do I check it hot/cold? Engine running or not? Fluid spec if it needs a top up? Cheers Jon
Jan 7, 2012 #2 M MB Tech boy New Member Joined Jan 4, 2011 Messages 13 Location Dorset Car CLC220 CDI, S500L You need the merc gearbox dipstick, it has a cold level (25oc) or a hot(80oc) level on it so either really, Car needs to be in P or N after running through the gears with engine running and you can top it up with mb ATF134 oil. Hope this helps
Jan 7, 2012 #3 S spike60 Active Member Joined Dec 31, 2011 Messages 291 Location It's grim oop North! Car 500 SEC, E320 cdi estate, BMW Z3 2.8, Porsche 944 2.7 Loads of aftermarket dipsticks on Ebay, I just got one for less than a fiver.
