W210 E55 spark plugs
kenmac
South Moreton Oxfordshire
2003 S500L Bright Silver 744
Morning
Can anyone recommend which plugs to use as all popular brands Bosch, NGK & Beru list them for it.
I'm assuming that Bosch would've been standard fitment.
Ken
I just used Bosch plugs bought from Eurocarparts when I replaced mine in my 43 and my 55 engines. This was from a recommendation from an Indy on here.
As I understand it the factory used to use Bosch but later moved over to NGK, certainly on the 55K.
Thanks for recomendations, I will order it
Might be of interest, but I went to buy a set of MB plugs for the 55 engine and they were Champion plugs in the MB box.
do platinum plugs NGK PFR-5R-11 work well on both c43 and e55 engines?
MB recommends service intervall every 40000km's changing plugs
Are denso twin tips any good ?
And off topic can I ask you guys who runs 55 engines if your engines are a bit shake on idling?
I have two w208 clk55s and on both of them the engine on idling shakes a little bit changed the engine and gearbox mounts,MAF,spark plugs, air filters and cleaned the TB.
The only thing I didn't touch the EGR valve can that one be a problem?
my clk430 shakes a bit, yet my c43 does not
2 clk 55's ?? wow !!! lol
Yep , mine the same! Stumbles quite a bit in Neutral or park, though in "D" sitting in traffic is fine. Most M113s do this, so I'm told. :confused:,and replacing the plug wires should cure it apparently. Be interesting if anyone has done this or cured this little niggle ?
I was thinking deleting the EGR valve would help a bit I will try to replace the plug wires on next service and will see if that helps
Lenny63 said:
my clk430 shakes a bit, yet my c43 does not 2 clk 55's ?? wow !!! lol
Two because I had an accident on the first one after I done a lot to it and the accident happened on the day when I got the cat guts out removed the middle box out the exhaust garage on the way home on the traffic light on a 40mph road with no brakes at all one hit me in the back
The insurance paid out and I bought another one and kept the old one as the insurance company priced it just under £400
When there are just parts that I put on that car more than that ))))
maybe you could sell me a back box and a seat motor :D ?
Thread ressurection...
How much is a reasonable price for an indy to charge for a spark plug change for a W210 E55?
Prices can be for labour only or parts and labour?
Just gauging up as I just havent got a clue....
Thanks in advance...
Indy guy near me is charging me £150 for changing the sparkplugs, oil and filter and air filter. I am buying the bits. £150 is for labour only. I have an ML55 AMG 2002.
BTW, I've been driving this for nearly 3 years now and there are no shakes, hiccups, farts, nothing. Bit thirsty but what the hell.
