Just an update on this for others who may have the same problem.
I have changed the spheres today, fitted a new filter in the reservoir then bled the system by disconnecting the self level actuator arm and manually operating the self level system up and down.
At first not much happened then after 5-10 minutes the car started to lift, at this point I stopped the car, checked the reservoir level and added more fluid.
Re started the car, up and down again then re attached the actuator arm.
Went for a drive and ?????? No change still clonking
Back on the ramps, more up and down, more fluid added as it took a little more.
Back out for a drive and still the same!
Had a cuppa whilst sitting looking at the back end and I thought it looked a little low.
Back on the ramps, adjusted the actuator arm from A: the lower hole to B: the upper hole (Not sure if it should have been in B all along?) and the last thing I did was unbolt both lower shock mounts (2 x 16mm bolts and nuts on each side) greased and re torqued.
Cured no noise at all
