Hello there.my mercedes w211 has check engine light on and it won't pass 2500 rpm with max speed 130 km/h.it doesn't go faster . Every opinion can help .thank in advance.
2012 W212 E350CDI Estate and 1966 VW Splitscreen camper
Check the codes with a fault code reader. Could be many things. Mine did the same when the MAF needed replacing as well as the EGR not working properly
Is your car a facelift? In Those car it may cause CEL, but should not cause limp mode IMO. Glow plug coil light works as it should? I think there is something else too, get it plugged in star...
No , it's not facelifted. It is w211 270 cdi 2004 .its start up well. When i kicked down over 2500rpm it make a klick noise in engine . Do you know what does this mean ??
