Brian WH
Job completed today.
Brake and Footbrake rubbers fitted using small screwdriver to run round rubber to lever edges over pedals. Fit rubber at top first and then the bottom and sides can be levered on afterwards.
Pictures of process for accelerator pedal are as follows: -
Remove split pin, squeeze end with pliers and withdraw using screwdriver as lever under head of pin.
Remove old rubber by pulling off at top and sliding off carefully.
Remove new rubber from new pedal from packet.
Slide on new rubber to your pedal in reverse to removal.
Refit Split pin and job done.
Total time 15 minutes.
