Who stole my radio's RF ?
Hi all.
I decided to continue with the similar issue on W211 220CDI saloon (late 2008 model, with new Command) : Suddenly radio reception became very poor.
Following things are now done :
1. Connectors are ok (cleaned), looks like no issues with lines in rear window
2. Amplifier (A2118707389) is replaced - no effect at all
3. Rear heater does not have influence
4. When Command is switched on and engine does not run, reception is better. When engine is running, reception gets worse (Xenon-lights do not influence)
(This would lead to a possible grounding issue - but where...)
I've understood, that there is a SAM located in trunk, however - dual coax-cables from amplifier in the left C-pillar looks like to lead to the front of the car -> are these leading the FM's RF-signal to the Command-unit, or are these cables used for another purpose ? (Separate GSM antenna is located on the roof.)
Or - would it be better, that I take a magnifying glass to my hand and go thru (>>10 times more) all grounding points.
I'd really appreciate all help regarding in this issue. Could someone share his/her knowledge of these cables ?
Br,
Seppo
Command
Amplifier
Lower connectors, note the coax cables is dual connector
Upper connectors
C-pillar connectors
