W211 comand module
rakeshkhakhar
Leicester
Mercedes E270 CDI Avantgarde 2003
:confused: hi all
i have been offered a w211 comand module with the following details:
MB Part number: A 211 870 00 89 001
Model No: 7039
firstly is this a newer or older model?
secondly does it play dvd....not bothered actually...
thirdly how much would it cost to get fitted into my w211 e 270cdi 2003?
please help
thanks
ok ...
as for the model check on richards' web site it will tell you which models are new or old.
More importantly you need to find out if your car is pre March 03, (with tape deck) or post March 03 (single slot CD). If its tape drive you are half way there since you have AGW in the boot. If not , well , its gonna get very expencieve ....
Hope this helps
You will need audio gateway and optics, {also the cd changer in boot the bracket and cables plus a new side trim to finish the job off proper with the little pull down flap} just done mine but i was lucky mine had all the above fitted as it was a cassette model yours has the gateway in the head unit and not the seperate one that you will need for the command unit.
so are you saying that my multichanger in the front has to be removed?:rock:
rakeshkhakhar said:
:confused: hi all
Model No: 7039
please help
thanks
This is one of the old models (early design) with no TV function. All W211 units play movies in DVD format. I would expect that it doesnt work if it is on eBay.
