I've got a W211 E Class with the 7G-Tronic gearbox and I'm having a strange problem.
After a while driving fine, the gearbox won't let me select Reverse or Park. I can only select Drive or Neutral. When in Drive it changes through the ratios fine though. I only know there's a problem when I try to go into Park or Reverse. The lever won't physically go into reverse.
If I stop the engine, I can go into park fine. When I restart I can then select all gears for a while.
I also can't change up and down the box manually when this is happening.
I've read the ECU codes and there were no fault codes stored.
Anybody seen this before?
