BillyW124
- Oct 22, 2010
- Location
- North West London
- W124 E320 coupe, W211 E320 V6 CDI, W211 E63 V8 AMG, R129 SL 280 V6, W215 CL 600 V12 Bi Turbo.
It's a facelift W211 with per-facelift wheels.
I'm not in it....!!
It's got waccy baccy plants growing inside
Strange lip between front tyre and rear of front bumper?
is it the suspension height ?
Look higher at the front ...
front arch gap
That's normal, both of mine have sat a little higher at the front. I had this one adjusted to take it down a bit.
Heavy diesel engines are probably (over) compensated for.
Not the same angle but you get the idea.
What does the indy say (I assume he did the job)?
Is the front on struts or do they sit like on W202's. If this is the case, perhaps you can play around with the rubber pads and "nibs" on the top of the spring. I stand to be corrected...
If it were incorrect assembly he's unlikely to have done it on both sides, so, even though you've checked the parts it points to them being wrong somewhere.
Could there be a mod involving the removal of some kind of spacer when the newer springs/shocks are fitted -even though you've checked the part numbers?
Grasping I know, but I guess you need all the ideas you can get.
