Crazy Mike
E220 Elegance 2002. (w211)
Front o/s strut removed from car and taken to local garage for replacement spring to be fitted. All done and returned back home to re-fit the strut to vehicle but realised the strut could not align to the lower spring arm for fitting the lower bolt as I forgot to mark the original alignment position.
I part compressed the spring and rotated the bottom 'fork' of the shock approx 45 deg, removed spring clamps and the bottom 'fork' of the shock aligned ok enabling the nut and bolt to be fitted correctly.
My question is - by rotating the bottom fork of the shock would I have done any damage to the shock ?
It seems to drive ok but there is a newish graunching noise when on 3/4 steering lock from the strut / suspension area that wasn't there before.
Any advice appreciated.
