W211 Headlamp Fuse
hi_flyer437
Somerset
E350 CDI Coupe
My right hand dipped beam has just gone. Having located the fuse box - no fuse allocation chart in it. Would anyone have the location so I can check that first?
Otherwise it's back to the body-shop who changed the unit about 4 weeks ago....
Thanks.
:bannana: (inserted at the behest of my 6 year old...)
Thanks.
Did you look for the fuse chart from other fuseboxes? Or from the tools box?
In any case, no need for the fuse chart, there is no (independent) fuse for the headlights.
Yes - no - thanks.
Thanks for your help - back to the bodyshop it is then. Great.
Are they Xenon or normal ? Have you tried changing the bulb ?
Xenons. After someone backed into the car a couple of months ago, the unit was replaced by the MB Approved bodyshop as the old one was cracked. I think the unit must be duff; initially the self-levelling feature wasn't working and now, about 6 weeks later, the bulb has gone. I've had the car 3 years and the other side is still up and running.
