I had the rear SLS on my 2003 wagon replaced by the Arnott spring kit after an airbag failed. The ride seems so much better now.
I have two questions now though.
The garage that did the conversion for me use AutoLogic. Is it possible with this to stop the error message I get now to 'visit workshop' due to the suspension change?
A couple of times with passengers in the back seats, the suspensions seems to thud as if bottoming out when I go over a speed bump.
Would rubber coil spring assisters help with this?
The car does seem to be sitting slightly lower than before.
Thanks.
Thanks.
