- Jan 10, 2019
- Location
- Cardiff / London
- 2x E350 CDI Sport W212s, Golf Mk4 V5.
Ah thanks! I was worried they’d carry tension when jacked up or something.Regarding the drop links, in my very limited experience I've never seen any drop links that are anything other than 2 bolts/nuts per side.
But doing drop links as a "simple job" has twice required me to use an angle grinder to cut the rusted nuts and bolts off due to being seized in a serious way.
It's simple replacing them after that, having left a couple of coats of black anti corrosion paint to cure on the inevitable bare metal on the anti roll bar from angle grinding.
Crack on Ed and good luck![]()
(I just want you to guinea pig this for me please)
I have a trip to Germany and back in mid August and lots of other important stuff that I need the car for so don’t want to risk ballsing anything up before then… I’ll probably tackle it at the end of August tbh!
