Yes, I would, but the number of hours of labour is quite significant so it may end up being quite expensive.
Another thing to consider. I am removing the ABC lines knowing they will be replaced. A lot of them would be difficult to remove and re-install due to being siezed, corroded etc.
We do offer an underbody clean and rust treatment with Dynax UB as a service already, but it doesn't include sanding, treating and painting the rust,brake lines, ABC lines etc.
That said, if the rust is not that bad, Dynax will halt the corrosion as its stands.
