W215 Passenger Side Mirror Issue
ea666
2015 CLS400, 2006 W215 CL500
The passenger side mirror has an issue where the mirror moves left to right, but not up or down.
I also have an "L. TURN SIG. RFLECTR" Check message which appears randomly.
Any idea's what this could be? or has anyone else experienced anything similar.
I had similar at OOOO A6 at was wrong earth connection
check and clean all connectors for corrosion
as well I heard when you have open windows and rain
Swich unit in door can have water inside and cause mirror trouble
Sometimes not. The loom can be repaired usually.
Just to update, i have fitted a brand new Mercedes mirror frame and indicator lamp today. This has given me full movement of the mirror.
Oddly the puddle light under the mirror case is still not working!
Any ideas??
I have a similar problem , same message now and again and mirror will not tilt down when in reverse
Hi Deane x, In order for the passenger wing mirror to move down in reverse the mirror switch has to be set in the left (passenger side) position. hope this helps
Mine doesn't have the tilt facility with it being a 2006 model. Apparently this has to be coded via the instrument cluster to have this feature. I'm still researching this....
Just noticed that the mirror also doesn't fold out flush against the rubber. Is there a reset that needs to be done?
