Well there you have it
You know better! And so does s.speed!
Better than genuine
I am sorry if I have offended because genuinely I didn't mean it..
Let me modify (pardon the pun) my statement...
Obviously genuine pads are of a high standard and they work very well indeed.
But for me one very annoying aspect is the dust they make..
On my car it means cleaning wheels every 2 days or so..
When I first tried the EBC green stuff pads some years ago (VW Golf) I was pleasantly surprised at the low dust.. The dust they did make was easier to clean off...The green stuff offered slightly more bite and didn't fade till a higher temp..
On a later VW Golf I tried the newly formulated Red stuff pads..
Even better bite and the temp range was higher still..
However.. One thing I will agree with you about is that the physical metal backing had to be slightly eased with a file as I do remember the fit into the carrier was slightly too tight..
Soo Yes you are correct that the finish could be better.. Once fitted though the braking ability was amazing...
My previous C270 cdi I fitted a full set of the Textar E pads..
These are a low dust formulation.. I wouldn't say they offered more bite than standard but they certainly made less dust..
I have to be honest and say that the quality of the metal backing was superb.. They fitted perfectly and the sensor fitted perfectly and connected without issue.
So to sum up...
MB are excellent but dusty..
Red stuff bite better and don't fade till a higher than standard temp, BUT the fitting is not 100%.. Could be better
Textar E Pads are about the same quality of manufacture and similar bite as MB but dust a lot less.
WG M-B I am sorry if I offended you..
It really want meant.
