Found some OMP ones at a good price. Job done
OMP is pro race stuff I had them on SWMBO Racing Puma, Interesting enough I bought them from YB racing as well they were brilliant under all conditions with very little dust, others I would recommend are Ferrodo DS1000 and Pagid are also good. The next set I will try will be the new ones that have come out from Sparco developed in conjunction with AP racing
If they are designed for race use how do they perform in a road car? Do they need to be at a particular temperature to work efficiently?
The ones in the link are for road and sport use (spirited driving) so you don't have to get them up to temp to work they work very well straight from cold.
The one designed for race use are branded OMP Pro and like most race pads they do work a lot better when warmed up, with cold temperature braking they do take a little bit of getting used to as they are not as good as standard pads.
Ian
Thank you
It is always good to learn!
Out of curiosity where do you buy your pagid pro pads from Ian?
Wayne,Out of curiosity where do you buy your pagid pro pads from Ian?
